aircooled1
- Concord, CA USA
1972 750SF1 - after some months of non-use I ambled into the cold garage and wanted to here the Laverda start up. Went to start it and nothing happened when I did the usual ignition procedure of key in and down - turn to right and fire the Starter Button. Result: No sound at all of the starter.
I could see the headlight works ok with key on.
I then tested voltage on the battery and I am a bit suspicious as it says only 10 volts. My battery tender says its full which I think is a fib. I tried to by pass the starter relay and the starter would not make a sound at all. So is that test confirming a weak battery? That it simply cannot budge the starter?
I also tested the handlebar switch and it does send voltage to the starter relay. I also tested the starter relay and found that it did not seem to pass on the voltage to to the starter. It does have battery voltage to the incoming side of the relay. So I feel my diagnostics are scattered. It seems the starter relay is not functioning properly AND the starter won't work when directly powered from the battery. It can't be both things gone wrong. It started fine a few months ago.
Suggestions? Should I just get a new battery ? Or disconnect the starter relay and test it better in isolation?
I will say that the horns do not work currently as I suspect the horn relay. But I am doubting this could be the cause because I bypassed it all when I hooked the battery directly to the starter and it did nothing.
