Poor/no tickover.
JO55
Full member
Cornwall
I having had low rev running issues since I bought my triple, I’ve done a number of things to ensure everything was just so.
After fitting the excellent Redex ignition/generator kit, my last job was to get the carbs rebuilt.
As I pulled them off, I discovered this. All three are the same. That’ll be the cause of the resultant air leak and inconsistent low speed running/tickover. Well, it gives me something to do while the carbs are away!
Anyone experienced this before? Manifolds appear to be cast alloy, with a some sort of composite spacer between them and the heads. Hopefully, they will weld ok …
Common as muck.
You will most probably find all stubs to be warped; done up far too tight, compressing the insulation spacer and ultimately snapping.
Remove the o-rings from the stubs and place their sealing surace on a flat surface, should be no wobble. Slightly distorted stubs can be dressed on a lathe.
New stubs, new spacers (with o-rings!!!), correct torque on the nuts...
Red can get you sorted with new ones, milled out of a more solid material. Customs is though a problem over here when goods come from Australia, but they are really worth any cent you spend on them...
Common as muck.
I suspected as much Piet. Thanks for the insight
Thanks. Yes, they always seem to clobber you for import tax don’t they.
you can buy them from Elegog on ebay UK. I have found that they need "finishing" (for the clip on ones, not the rubber mount ones) as the dimension are just a tad too tight (maybe he has a very cold workshop) and needed a bit of relief, nothing more than a spin on a lathe and rub with some 600 grit, maybe 3 or 4 thou. I dont see the need for a heatproof spacer, if they are mounted with rubber tubes and four jubillee clips, I dont use them anyway, but is this needed? a tad hard to see if yours is clip on type with a plastic sleeve in the carb throat (very easy to crack the bodies of those carbs) or the Jota 120 type with rubber tubes
