Restored Jota 120 on eBay - San Francisco
Here is part of the response I received from Moto Bella. The parts list and details is at the end. There is also a large zip file with many pictures that I will post if I can. FYI the bike had 19k miles and was stated to be Pieros personal bike and also used for factory demonstration. The founder of the Museo Laverda has all ownership documents available upon request. I was told there is a offer in hand, but they were open to higher bids, although that may simply be salesmanship.
1983 Laverda Jota 1000 - 120°
Concours Restoration of Legendary Italian Superbike
#D-241
Offered at $32,975
This Laverda is the first bike created by our partnership with the new Museo Laverda in Breganze, Italy, home of the original Laverda factory. This meticulously restored Laverda Jota is a remarkable example of a special motorcycle. Previously owned by Piero Laverda himself, who sold the bike to the Museo seven months ago. He recently saw our finished restoration and declared the bike “Better than when it left the factory!”.
A remarkable example of a unique Italian sports bike in excellent condition … a great addition to any serious collection and a real experience to ride. If you want the very best and can afford it ... this is your Laverda.
This Euro-Spec Laverda has been fully restored by the Museo Laverda team of experts in Italy.
Very low original mileage.
Overall cosmetic condition is literally better than new, restored to a Concours standard in all regards.
Paint, bodywork, seat, wheels, chrome, instruments, tires etc. all in “as new” condition.
This bike is very faithful to the original specifications.
Completely rebuilt and serviced, runs and rides like new.
Extremely fast, very rare, serious and extreme - a machine for skilled riders only.
Bike is arriving early this summer from Italy and will be offered with a clean and current California title and registration.
The Laverda Jota is a 1000cc three cylinder Italian super sports motorcycle that was top of the line and one of the most expensive production bikes available in its day. It was noted to be the fastest production motorcycle in the world at the time of its introduction. Laverdas were a premium brand with outstanding performance, built using the best available components, proven in racing and always priced at the top of the market.
Considered the top European superbike of its day the Jota was a performance showcase for Laverda and had a very successful racing career. The first series models were rated at around 90 hp, and could exceed 140 mph, making the Jota the fastest production bike of the era. Race versions went on to win the UK Production series in 1976, '78, '79 and '80.
The 1000cc three cylinder engine was over designed with multiple ball and roller bearings and is very robust. It was originally fitted with a crankshaft with 180° crankpin phasing and ignition timing on the right hand side of the engine till 1980. Then in 1981 the ignition timing was moved to the left side in a new all-electronic unit and in 1982 the Jota 120° was released which had the crankpin phasing to 120° which made for a much smoother engine. The bike being offered here is a 1983 Jota 120° that has been fully restored by Laverda experts in Italy.
Late series 120° 3 cylinder 1000 is smooth and extremely powerful and has been called the “best sounding engine ever heard”.
Truly amazing just to listen to, and even more so to ride. The Jota is hefty at almost 600 pounds, but very well balanced. Handling is solid and stable, suspension is on the firm side and the brakes are top of the line Brembo for the period.
All electrical components and switchgear for the Jota are German Bosch or Japanese. The 1983 Jota had an upgraded 260 watt Nippon Denso alternator. These premium components make the Jota a very reliable and trouble free model.
The Jota has a rich history and is one of the few classic bikes that can exceed any and all expectations you could have for riding it.
They say don't ride your heroes. Well, here is a bike that definitively lives up to its lore.
SPECIFICATIONS :
1983 Laverda 1000 Jota 120
ODO 31044km / 19289 miles
Category Super Bike
Engine and transmission
Displacement 980 cc (59.80 cubic inches)
Engine type In-line three, four-stroke
Power 86 HP @ 7900 RPM
Top speed 131.1 mph
Compression 9.0:1
Bore x stroke 75.0 x 74.0 mm
Valves per cylinder 2
Double Overhead Cams/Twin Cam (DOHC)
Air Cooled
Gearbox 5-speed
Chain final drive
Chassis, suspension, brakes and wheels
Front tire 100/90-18
Rear tire 120/90-18
Front brakes Dual disc
Rear brakes Single disc
Physical measures and capacities
Weight incl. oil, gas, etc 265.0 kg (584.2 pounds)
Fuel capacity 20.50 liters (5.42 US gallons)
RESTORATION SUMMARY
PCS.ITEMS
Sandblast and Painting of frame and all body panels
Replating all chrome parts
2Replaced hand grips
1Throttle cable replaced
3Choke cables replaced
1Choke lever cable
1Tachometer cable sleeve
1Speedometer cable sleeve
2Pilot foot pegs
2Passenger foot pegs
2Pet cocks replaced
2Emblems round for side panels
1Steering lock replaced
1New Gas cap
2Rear wheel bearings
2Rear hub bearings replaced
2Silent block for exhausts
All Rubbers have been replaced
2Rear hub packing gland replaced
4Fork Rebuilt with new oil seals
Disassembly, wash, and blast of 4 shocks
1Wheel bearing for crankshaft
7Clutch plates cork type
6Clutch plates Steel
1Pinion holder gear roller cages
Engine Oil seals replaced
1Distribution chain
2Primary transmission chain
3New Pistons diameter 75,4 complete with rings and bearings
Boring of cylinders
Chain tensioner
3Valve housing
Valve Job & Seats
3Oil seal valve guide
3Spark Plugs Champion N3C
1Engine gasket set
3Vacuum sleeves
6Vacuum sleeve clamp
3Levers Carburetor gasket
3Pulverizers
3Conical pin
1Floater pin
3Max Jets
3Min Jets
3Needle valves for gas shut off
3Return pump membranes
1Carburetor post support
Front tire replaced
Air tube front replaced
Rear Tire replaced
Rear Air tube replaced
6Brake Disc secure pins
2Safe pins for screws for crown holder
3New Brake Pads all around
1New Engine starter rubber cover
1Rear wheel drive chain
Know of 2 sold in Oz recently for slightly more and slightly less of 30000 oz dollars. The slightly less was in nowhere near the condition of the one offered and definitely didn't have the sort of money thrown at it like the one offered. So comparing it with what what has sold in Oz I think it is good value.
81 Jotas are in the 40k price bracket these days. I'm talking Oz markets.
#D-241
Offered at $32,975
SPECIFICATIONS :
Category Super Bike
Top speed 131.1 mph
Compression 9.0:1
Air Cooled
Gearbox 5-speed
Chain final drive
Rear tire 120/90-18
RESTORATION SUMMARY
PCS.ITEMS
1Choke lever cable
2Pilot foot pegs
2Pet cocks replaced
1New Gas cap
1Distribution chain
Boring of cylinders
Chain tensioner
3Valve housing
Valve Job & Seats
1Engine gasket set
3Vacuum sleeves
3Pulverizers
3Conical pin
1Floater pin
3Max Jets
3Min Jets
Front tire replaced
Rear Tire replaced
That's receipts! The price is right.
Really? Specifically 1975 SS models? If the USA bike is good value in comparison, do you mean that two in OZ sold for around $300,000 rather than $30,000?
The cost of refurbishment these days is way too expensive. FFS, for that money you could a lot of motorbike. Oh, no. I wouldn’t know what to buy with that sort of money…..
Something one owner, fast’ish, nice sound, slightly classic, nice looking, tallish, lovely looking engine, sports tourer, lightweight wheels, trick suspension, legendary reputation. Not Jap, Brit or Yanky.
Ah poo shit, sounds like I’m buying TTWs 1980 Jota.
Not for sale Chris, thinking of leaving enough money in the will to have the bike buried with me. Wouldn’t be telling you where I’m getting stuck in the ground though😂😂😂. Seriously that 120 Jota is a lovely bike, some of you guys need to take a chill pill😀
Tom
The Jota wasn't considered the top European superbike because it wasn't homologated in several countries.
Is 9/1 the compression ratio of a 120° Jota? Low compared to a 180°. What cams are in there?
As for the price, sorry to disagree. My 3C had more work than that done on the engine including Arrow rods and dynamic balancing of the crank, a new head and 1 camshaft, new discs, all new bushes in the gearbox, new exhaust complete and some. The restoration cost me probably around £ 11 000 sterling.
I suppose import duty is high in the US.
My 2 cents worth- Great looking example but I consider that the price includes import costs & commission for two sellers...
My import costs from England to Oz for the bike I am buying are INSANE unless it's a really special bike unavailable locally so any recently imported bike costs compared to local bikes to the stratosphere.
  • Like
Reactions: IAG
Double that. And that's a one-way trip. It hurts. It's got to be an exceptional bike or circumstance to justify the Insane cost. This is a once-in-a-lifetime thing for me, so I made it happen.
