The spline has a dot & the oil pump gear has a dot. They line up. Ok the arrow to line the oil pump gear on crank to oil pump drive gear is about 6 teeth left of dot. This aligns w/ the oil pump drive gear arrow. Thought the arrow was supposed to be about 120 degress right of the dot on oil pump gear. Ballpoint pen shows position of arrow on manual. Has to be as is. Right? Don't remember this one. Then when aligning w/ timing chain gear to head marks on top all falls into place. & then the threads of the crank nut are recessed on one side. Recessed threads goes to the inside. & then should I put the primary chain in the oven before fitting on the crank & clutch? Last time I did it was in the summer. It was hot. Wrestled w/ it for an hr. Sweating all over. (& then the oil pump drive gear peg fell out of shaft but it fits back in OK)
