Not today, but a few days ago. Brought it home from my mate Hal's place (forum member Aldo). For a while now he'd been giving me a hard time about never cleaning the bike. I can't remember the last time it had a wash. It would be several years ago at least. I'm not the sort of bloke who cleans bikes. So long as they're clean on the inside and the external dirt isn't causing any problems, I'm happy. Anyway, he offered to give it a clean for me, so I trailered it to his place and left it with him for a couple of weeks.
Here are before and after photos. Sorry, they're not from the same angle. I didn't plan to do this before and after thing. But Hal did such a nice job of cleaning and detailing that I thought he deserved some credit. I dunno how he got the oily grunge out from between the cooling fins and off the engine, but the bike's cleaner than it's ever been during my ownership of it.
It's a pity Hal couldn't polish the cracks out of the side covers. When I bought the bike the side covers were pretty tatty. Cracked and missing a prong or two. That was one of the first repair jobs I did on the bike. Missing prongs replaced inside, cracks glued and reinforced inside with fibre epoxy. So they're good and solid now, but the old cracks in the paint are still visible.
Now all you sharp-eyed buggers can start commenting on all the things that are wrong with the bike.
Whats he like at polishing Atlas Plastic, I have the kit and just maybe it might head to Tassie in November.
I’d have put the red straps at the back🤣
That’s a two slab job! Cough up Cam, seems Hal ain’t so Shallow after all
Please tell Hall if he's looking for any more work, I have plenty over here waiting for him.
Travel expenses might pose a bit of a problem, tho' ...
cant fool me, its not the same bike..... for one the "1000" suddenly appears on the rhs panel.... nice work as you say Cam, Hal is indulging you... j.
Got the SF2 ready for this year's summer tour.
It'll only be two weeks touring this year compared to the usual 4 or 5 but a few weeks back, I was still on crutches so no forward planning.
Nothing very wrong with the bike apart from a lot of wear and tear. 50 years old and 150 000km.
We'll probably be doing 2 to 2500 km towards Eastern France. The Argonne, taking in WW1 battlefields including flying over them in a small plane; then up towards the Ardennes, French first, then Belgian and back down via Reims and it's cathedral. Probably the finest of gothic cathedrals.
Timing was a bit retarded. Tappets ok. I took the screws out to check tips. Screws have seen better days, valve stem tips are fine. Tensioned the primary and cam chains. Will have to get around to changing the cam chain some day though it sure ain't stretching anymore after probably 120 000 km.
Secondary chain and sprockets are ok, brakes ok as well. Rear tyre will need changing in the year to come.
Checked the synch on the carbs by checking that the slides lift equally. Will set idle and mixture when I've warmed it up a bit.
It's Official, I've got my tyre mojo back!
Replaced the front, this morning, in double-quick time. The new one practically fell on.
It is true that it's easier to remove the old tyre from a wire wheel than a cast one, replacement is much of a muchness.
Another reason to get yourself a proper Laverda, not one of those "jotter" things.
Went riding to test the SF2. The slightest hint of a misfire no doubt due to a sealing problem with the exhaust at the head. It's been there since I changed the tubes and under engine banana.
