Shuggie
Full member
- Scottish islands
To make a custom polished yoke
Nice, hope you don’t cover it up with the car steering wheel horn pad looking thingTo make a custom polished yoke
What master cylinders are you using?No , I definitely won't....I'll grind and file down the handle bar bosses, get the holes filled with weld by a coded welder
I like yellow cars and bikes, if I had it to do over I’d probably paint mine yellow instead of blood orange. It’s just hard to get a yellow that has real depth and richness. I’m not a fan of most chrome yellows for this reason.Nice yellow![]()
They're Nissin 14mm for the clutch and 12.8 for the brake...both work well , plenty of feelWhat master cylinders are you using?
Yes it's nice for a yellow,the surface prep wasn't done right when it was painted so there's defects under the lacquer....I'm thinking of getting it painted with the correct flexible primers and clear coat in Ferrari Energia Rosso pearl micaNice yellow![]()
Thanks. 14mm clutch was original, I’m now using 13mm - easier on my handsThey're Nissin 14mm for the clutch and 12.8 for the brake...both work well , plenty of feel
