Now the turn of modern restorers.
iis_iis
NSW
Just attempted to put my TLR back on the road ( to sell ), quickly became apparent that all the skills garnered here for keeping Laverda on the road, are also for the "modern" bikes of 2000 and on. Just like the Laverda skills in resto, the modern resto has significant unique demands.
Modern fuels left in fuel tanks, overwhelming rust and contamination residue that permeates through the fuel injection system, have now a Gixxer 2003 of a friends which is worse than mine by a significant degree, his friend has a TLR, $3500 to rectify the fuel injection system.
Limit this post though have now, just like Laverda restoration skills, produced new methods of modern repair process, including part dismantle of fuel injection pumps and restoring to correct psi performance, saving many hundreds of dollars doing so. Cover more details as may be of interest, including the chemical process that bypass filter systems and produce solid contamination on the "clean" side of the filter, bizarre fathoming how the injectors were seized post filter. j.
I feel your pain . I had two bikes in store for several years, alhough they should have only been in store for a couple of months. One was a Guzzi T3, the other a Gpz900r. When they were finally brought out of hibernation, the T3 started on the 3rd time of turning over. The Gpz wouldn't run. An absolute mess in the carbs and the fuel tank. Happily the Gpz has been fully rebuilt and is now on the road.
I feel both your pains.
Went to fire up the ZXR7 after a two year layup. The stale fuel was gross, the carbs full of crud.
Carbs apart and into a bath of Yamlube carb cleaner, tank cleaned out and vroom on the button 😘
I think it despised the Yamaha product going into it so much, it fired right up, just to spite it! 😉
Glad there was no pump in the tank though.
Tah for the sympathy pains, though really it is the grail err i mean win we seek. Gives me a real boost when am able to pull a sealed pump down enough to mechanically free up the armature, then chemical treat the internals from the outside, molasses in the tanks, has done an very good job, overall. Pumps ( both partial rebuild ) up to 75 psi for a 3 bar injector rail feed pressure ( gixxer has the pump regulator imbedded on the filter canister body inside the tank, ie there is no low pressure return rail from the injectors on the gixxer, the TLR has a low pressure return and manifold pressure reg on the fuel rail proper ).
Test bed is make a return hose to tank lockable filler from the HP tank outlet, external power supply to control the pump and run the pump continuously, connect pressure gauge to HP outlet, 45 psi on the dial... win.
Lot more to the work involved though you get the idea and basics, main point being modern restorers will need to be resourceful like we were in the days of no Laverda factory support, somewhat self satisfying in a perverse suffering way as we battled to create skills for the age related issues. j.
Now this may sound stupid but I was told to mix two stroke oil with the petrol in the tank when laying a bike up for a while because the additives in it bind the fuel components together, otherwise they separate and create havoc. The information came from a good source but I'm not knowledgeable enough to question it. I might give it a try though.
I have done that for years, more to get a coating of oil throughout the engine before storage. Still draining the carbs, but leaving the fuel in the tank with stabilizer. Thinking its also a rust preventative in the fuel tank. Mixed at about 100:1
If I think a bike isn`t going to be used for more than , say , a month during the winter , I wait till there`s the bare minimum of fuel left in the tank , then turn off the tank taps ( or tap ) ...... then run the engine till the carbs run dry .... no fuel left in them to corrode or go off .....
These are carb`ed bikes though ......... not so sure if that would be the way to go with EFI and their pressurised systems .......
In aviation the idea is to store with tanks full. The theory is that the sun heats up the tank expanding the air inside, expelling some of it and as it cools back down in the evening it draws in outside air through the tank vent. This air contains humidity/moisture which then condenses in the tank. The less airspace, the less air to be exchanged which minimizes the condensate in the tank as the days and weeks go by. This happens outside and in the hangar or garage, anywhere there is a temperature differential between day and night.
My jurisdiction (Canada) has very recently ( July 27, 2023) banned all non ethanol gasoline, with now minimum 10%. Honestly I’ll guess less than 30% of owners of machines badly effected by “modern fuels” are aware of this change.
I’ll predict that the typical enthusiast of a machine ( 2 and 4 wheeled) in my country that waits our the winter here (3.5-6 months) will be very aware of the problem, and that fuel system management and especially winter storage are now critical.
I recently had a chat with a highly esteemed Laverda owner who lives where there has never been 0% ethanol available. Pouring straight atf automatic transmission fluid into the carbs through the winter has worked for 20 yrs now.
Am unaware of what a "fuel stabiliser" chemical constituent actually is, moreover different suppliers of same. Chase that up, though with modern times we have modern answers that read as a PR blurb than actual technical usefulness, there is no hiding in MSDS information. Pretty much what i do in the early stages for chemical compounds and mixtures of commercial products.
Initial outcomes of long term fuel effect on fuel systems is two parts, rust and chemical residue, two different effects in say the fuel tank. The rust is addressed, as ever we do on Laverda tanks. The residue is more complex, seems to be variations in this, as the gixxer had fuel stabliser added and initial observance would suggest added a secondary "coating" or catalytic effect on the internal tank surfaces, you can see the strata effect in the tank for these surface contamination(s). Exactly where the fuel level effect in the tank, above and below the "water line".
May well be the best responce in mitigation will come from time honored lay up basic treatment and then full understanding of what modern fuel residue can be reduced, and that will come from the vast experienced folk here, dyi at the helm. j
Since I have several bikes running, I can assure you that I don't take any particular measures. They fire up after 3 months or more, every time.
Take the win where you find them Paul, not universal at all, come the day stored bikes will have issues. j
Right you are Chris, my 3c was loaned to Caustic Chris ( UK ), he did not want to ride the TLR and so it was.... a TLR on a Laverda rally... with photo of group your in as my recollection serves.... dem were de days...j
( to you ) Thats "Spring on a Stick" Vince, the damper is out board of the shock spring, think of it like a hydraulic door closer, odd you say.. not a word of it...a smile here. After weeks of rooting around, the TLR starts and idles, 10Krpm on a blip of throttle. j
