Leave the steering stem be and polish.Wanting to polish the yokes, I'm trying to get the bottom yoke off the steering stem of an early 3C with 38mm Cerianis. I'd presumed it too should have the stem driven out downwards through the lower triple clamp but it's not budging even after several times left cooking in the gas BBQ very hot for a while.
In this case should it go out through the bottom? Stem looks like it may be about 1.5mm larger diameter on the underside than on top.
I don't have easy access to a press, is there a technique other than larger BFHs?
I got the lower bearing off with a pair of screwdrivers but otherwise this is what it looks like.
