TeddyG
- Portland Oregon
I know the purists don't believe in turn signals, but I've mounted these rear Lucas turn signals to the black and green wires as shown.
With the black wire connected to the left turn signal and the left indicator switched on, the left flasher just stays on with no flashing. When the right indicator switch is turned on, there's no light and just chirping from the Lucas relay.
With the wires reversed and black wire connected to the right turn signal and the right indicator turned on, there's no light and only relay clicking. If the left indicator switch is turned on, the right turn signal turns with no flashing.
The wires will be properly routed once things are working.
So is it a defective flasher relay, or do the front turn signals also need to be mounted ? (but there are separate green and black wires running to the front of the bike).
Thank you
Thank you
