Always kneel to play a member..I once played a member of the crowd in a porn film.
Having turned 60, I am now more like Dick Dribbler!i'm actually Dirk Diggler.
www.advrider.com
Luxury AssortmentNose in the trough. View attachment 90153
Even less for the giant roulette wheelMy 5 seconds of fame!!!
Has your bike got a 270 crank or 360?No photo from me but Hooksey has done the deed! Attended the Vic Lav Club monthly last night on the SFQ for the first time sonce last November. Bike purring, but on departure I started her up no drama but a spit back (very cold evening, no choke on the FCRs) and stall resulted in a starter button that did nothing but create a lot of whirring noise down below. Dumbstruck that I could have broken yet another woodruff key and thrown the starter freehweel off the taper for the 3rd time in two weeks we (Hooksey and two other club members who were luckily still there!) pulled the starter cover off and lo and behold, there's a broken starter chain!! It's actually a used genuine Regina triple cam chain that's been used since my Perth days 40 years ago. That's a serious kick back from the motor!!
Two attempts on a 3rd gear push start on the slightly downhill hotel carpark and I JUST managed to get it alive. Rode home without drama. Thanks Hooksey!! No way I can push start that beast on me lonesome. Other than that, no more ugly noises from the motor.
That's some crazy shize alright Vince. Are these guys trying to start KTMs on FCRs?Q did you say your FCR carbs don't have a choke, some crazy info on that subject. Some on downdraft are not relevant.
Chokes for FCR's
so seeking any constructive advice or ideas two options I am considering : 1. butterfly chokes in velocity stacks ( not the best but plausibly...www.advrider.com
Hopefully nothing to do with the ignition..?That's some crazy shize alright Vince. Are these guys trying to start KTMs on FCRs?
Mine starts very easily with 6-8 squirts of the accel pump while holding the throttle open to clear the run from the nozzle past the slides, then closed throttle hit the start button. I've cured the low throttle stutter by fitting leaner root diameter needles and bigger slow fuel jets - might be why it's a tad lean and kicking back. I think the secret to eliminating it is to keep the revs higher for a few seconds once it fires. I'll be experimenting. Don't want to have to deal with the ramifications of the big kickback.
It's unlikely - brand new V96 Ignitech box and can kickback with either of two Hall Effect pickup and trigger systems and the same settings. Once going it is as steady as a good clock.Hopefully nothing to do with the ignition..?
