Exmoor beast
- Minehead,Somerset, ENGLAND OF COURSE
I have known some guys to lathe off a few mill from one side of an enduro rim to make a mouse easier to fit.I once watched Shane Watts change 2 bib moose in well less than 10 minutes with probably 10 levers, 600mm long tyre levers in the parc furma of the 6 day. They must practice for weeks.
I have just found a 12 v tyre machine that the mobile tyre fitters use, bigger, heavier but certainly up to the job. I’m not convinced with the lightweight manual type, bead breaker looks flimsy and they seem to struggle in ideal circumstances. Real tyre machines have an active roller ducks beak shoe made of steel whereas the manual type seem to have a molded plastic version that distorts badly when using levers ( the one in the video I watched) . Long & short of it is you need a proper tyre machine, the cheap ones are just that or you perfect the use of Michelin style levers, decent tyre soap and a bead breaker that’s up to it. If the wheel is held firm I can generally throw the tyre on the first bead then it’s just a case of working on the other. Humming & harring myself about getting a machine - I’m doing more and more and local tyre shop doesn’t like doing lose bike wheels at all due to damaging the finish.Carry spare set of wheels with wets on!
Reason for looking - Local tyre dealers are unable or can not buy in the racing tyres I require , for instance currently have Michelin Power GP2 tyres.
Secondly they are not happy about putting tyres on they don't supply, due to insurance .
Where as in this country, the majority of racing events have someone supplying/fitting tyres in France for instance it appears not from my experience. Also even if there is doesn't mean they will have the tyre you require.
Tyre levers I've used in the past, but should be used to a minimum to save damaging rims etc on wheels costing thousands.
My reasoning on buying in a portable system covers both objectives, also with such a system I can leave the responsibility to changing tyres to some one else in the team.
Andy
