As can be expected, the GTL is grimy af. The pressure washer will make short work of that.
Total distance covered just shy of 8000km, Wokis odo shows slightly above 8000... chinese km maybe?
Casualties are the mentioned rear indicator and that stupid clutch cable, the RH fork leg shows some oil weeping from the gaiter. Chain required some lube and one tensioning over the distance. Oil consumption less than a liter. A squirt of grease into the swingarm pivot, lube for the levers and pedals, the primary chain needs adjusting, valves checking, that seems to be it. Oh, and a new clutch cable, the replacement is a tad too short to route as desired. I'll just knock up some nipples in brass and solder a new inner, the broken one was perfect. Not sure about the steering head bearings, I think I feel a little movement, maybe an adjustment will suffice.
Overall, not too bad for a 50-year-old old clunker with 70000+ on the odo.
View attachment 98177View attachment 98178View attachment 98179View attachment 98182View attachment 98183View attachment 98184
