smlav
- Shropshire UK
I’m chasing some electrical gremlins on the SF1 light switch and would appreciate any knowledge. ND switchgear and fitted with separate relays for high, dip and horn. High and low are intermittent, particularly high. With the headlamp bulb removed, the 12V to the bulb connector from the relays is solid when switched on, high and low. If I connect the headlamp bulb, the 12V at bulb connector and relay output stops. Adding the load of the bulb causes something in the loop to stop passing current, my prime suspects being relay contacts or left handlebar switch. So I started by dismantling and cleaning the handlebar switch. This post is about the horn button which has stopped working after rebuilding switch. I'll come back for the light issue if I don't isolate today.
The horn worked solid before I dismantled the switch. It works if I put an earth straight to the relevant wire on the connector inside the switch. The indicator part of the switch has three wires, the black one is a solid earth. I can see that the horn button has a copper post which when the button is pressed strikes a contact opposite the horn wire, and that should earth and activate the relay/horn. But where does that copper post on the button get its earth from? Is it somehow from the black earth wire at the indicator part of the switch? Or is it from the switch body, which doesn't appear to be earthed (with switch off the bars) - should it be?
Thanks. Sean.
Thanks. Sean.
