My brother has 1000S with a slightly modified engine.
No chains in the engine. Twin spark plugs per cylinder.
It’s a lovely bike to ride.
Handles well, good torque and power characteristics.
He finds the riding position a little compromising but has recently had two new hips and that was a major game changer.
It has a much better gearbox to a similar era BMW. My BMW Boxer has a Cray rebuilt gearbox and is now similar to the Moto Guzzi.
Controls are good but my brother did find the throttle a bit heavy but we got that sorted with new carburettor tops and better cables.
Has given him years of pleasure.
How do you rate them….?
Bought mine new when I was 23, got cheesed off with the heavy Dellorto’s and fitted Mikunis off KLR650 . We had to change new carbs on showroom bikes as Kawasaki went to water heated version so I had brand new ones in the tool box - come in handy one day. When I worked with a Dyno I fitted carbs, CND Bruce dissembowled the stainless exhausts and I fitted Dyna ignition - it’s been that way for thirty odd years.
Motor is big valve version, very strong, pulls top from 30mph - 120mph. Doesn’t use any oil. Once did Watford to Okehampton in 3 hrs dead after work .
I’ve toured all over Europe, 13 hour days, 550miles on A roads - it’s awesome at long distance days. It handles better fully loaded, slow steering and likes to be in too high a gear climbing out of corners using the torque. I bought it without having ever ridden a Guzzi- everyone warned me “ Italian Electrics, reliability problems…” I can honestly say it has never left me in the lurch- I’ve popped & banged into Le Mans ( of all places!) with a cracked plug cap, and I had a coil that would play up when hot coasting down hill. Just recently I had a brake hose break up but it is 33 years old. Little bit wrist heavy at slow speed & the footrests are too high- I’ve thought about moving them but it’s a bit of a faff.
Without doubt my best purchase ever- I ordered one with Mag wheels and it came with spokes “ it’s the last one available..” I was told which turned out to be true. Never going to sell it, I have literally grown up with it, my kids call it “ the big Guzz” & I have ridden some epic journeys on it. I used to joke that if I took it to Italy it would find its on way to the factory- I did go to the factory and got lost and I swear the bike made me take a left turn and I ended up outside the famous factory gates. Yeah , I suppose I do rate them..
Just found a picture of the Guzz in a Forest in the Pyrenees- I took a track thinking it would turn into a road- logging track in forest..
My brother's has Dyna ignition and has in the past burnt out coils.
What Ohm rating are you using on 'the big Guzz'?
I went to green Dyna 3 ohm coils because I thought the ignition might have caused the original points coil to fail. It was odd because I had resistor plugs and caps that were letting the coil “ build up “ and masking the problem. If I coasted down hill it would pop on one cylinder then stutter before clearing like a flooded carb. Took me a while to suss it but I used to run a third coil as a spare on the bike so just switched it over. Definately run Dyna coils with a Dyna ignition . Original coils weren’t all that and were known to fail.
Thank you, my brother's 1000S has 3 ohm dual outlet coils, Dyna. and has had a repetitive fault of coil failure. I will ask him to check what plug caps and plugs he has as that may be a contributor factor. He is in Crediton Devon.
FOIM, lots of nice bike down there in Mehikko, Hooksey
I thought it was a no no to run both resistor plugs and caps together. I thought it was one or other. 🤔
It is! My caps broke up in France ( NGK both caps went crumbly?) and I bought some in a Honda shop in Le Mans . I was just thankful to get some caps at the time to get me home- so that’s how I ended up with double resistors on board. You are exactly right but it acted like a “ button” giving the coils longer to build up.
