TeddyG
- Portland Oregon
As above, Mondial pistons and rings in good shape, thanks
Why specifically Mondial's?As above, Mondial pistons and rings in good shape, thanks
It has nothing to do with oil quality.Thanks Pirhana,
I,ve gotten different opinions about the piston wear, from incorrect re-bore clearance, to gas wash, to oil starvation. The wear on the Ross has been measured by a machinist who says it’s beyond spec, and the bore was remeasured and found to be true with correct .003” clearance.
The oil was analyzed and I was told the gas content is acceptable, it could be from the different skirt design, and possibly from using Bel Ray 20/50 mineral, and that a synthetic blend would be better.
So I’ll try the Ross w better oil and hope for the best.
.003" seems tight for a forged piston. @redax5 will know. @TeddyG - I have a stock bore 750 barrel if you have a need, name your price!Thanks Pirhana,
been using Ross pistons for close on 20 years now and yes I get them ceramic coated on the crowns and anti-friction coated on the skirtsI'm no expert, but aren't standard Mondial pistons cast, and Ross are forged? The latter are way stronger. Pretty sure Red gets his pistons coated to up their game even more to withstand really hard use.
I bore and hone barrels to 0.065-0.070mm to suit the Ross pistons including on my race engines which is slightly tighter then 0.003".003" seems tight for a forged piston. redax5 will know.
