I'm having trouble getting my exhaust system with the big under engine balance pipe to fit properly. I have the exhaust pipes and collector box that came with the bike and a set of nos Conti silencers from Wolfgang. The bike was in pieces when I got it so I don't know how well things fit originally, or if something may have gotten bent in 35 years of storage. I have managed to get everything bolted together and the exhaust system looks right but on the right side the collector box/balance pipe is just slightly more than a millimetre from the frame cross piece just behind the gearbox, and on the left side the exhaust pipe is .5 mm from the head of one of the primary cover bolts. Surely there should be more clearance on both sides. How much clearance should there be ion bikes with under engine balance pipes?
If I can't figure anything else, I may take off the balance pipe, heat it up and bash more relief on the right side. Anybody got better suggestions? I know I could eliminate the balance pipe but I don't want to do that if I don't have to. I don't know if the photos will show what I tried to explain.
