Heel Toe gear shifter Alinment
Vince
Is there a typical alignment for heel-toe gear levers? Do they align in a straight line front to back, level with the top of the footpeg, or is the heel pad slightly higher or lower? Are both the toe and heel bits the same length forward and aft to the centerline of the footpeg? Does the boot heel usualy 20mm thicker have any effect.
Totally custom arrangement on my bikes, posties are flat.
