Clutch Push Rod
motoddrob
S/W Australia
Does anyone know or have the ability to measure how much the push rod sticks out from the end of the the counter shaft spline??
That would be a S1 motor with cable clutch
Cheers
Rob
Rob there was a huge tread on this,Paul was looking at it a while back.It had the total length of the rods and ball bearing and the size you are after in it.The length of these rods needs to be within a mil or 2 to work.And the ends need to be case hardened.Lots of presure and quick wear if there 2 soft.
motoddrob said:
Thanks Rob.
I used the search option, "clutch push rod" and only got the above post in results
???  I reckon the sun's getting to you guys  :D
        the message I dug out from Mark from da canefields said 11mm for a cable clutch after he fixed his
        before that Piet gave the individual pushrod measurements -
Pushrods for cable operation, 123.5mm.
        Pushrods for hydraulic operation, 133.5mm.
Hmmm, I am having troubles with setting up the clutch with a brand new Wolfgang cable. Big ball on the lever end, two rods with a 6mm ball in the middle, 123.5mm each. The arm is too close to the case/drive chain. The inner cable is way too long, but measures the same as the old cable.
Can I put 2 ball bearings in?
Gee an old thread.
Memory serves me well 11mm is the go. I've never liked the feel of my clutch, has the extended arm.
I find all my spare cables, standard cable length varies some.
All the adjustments, lever and motor are maxed out. I even put a 10mm spacer down on the motor end.
Its such a wishy washy feel I thought fuck it and ordered Reds hydraulic conversion. When I get home that'll be waiting for me in my post box
Is the arm coming too close to the crankcase when the clutch is pulled in? If that is the case I have fixed it by shimming out the lever base in the outer case a bit to get full travel again.
If you decide to make a longer clutch pushrod, both ends need to be case-hardened. When this happened to me after fitting a set of new clutch plates, stupid me used what I found for sale in a local nut-and-bolt shop, something called Silver Steel. They sold 600 mm lengths of stainless steel rods of the correct diameter that I cut to the correct length. It worked great for approximately 20 km when I started to lose clutch adjustment. These pushrods put so much end-point load that my stainless rod wore away by a couple of mm for every 10ks travelled. Every day is a school day.
Vince, I use Silver Steel and case harden the ends, been doing it for years as have to make custom push rods to suit the outrigger bearing set up on my race bikes
Is not difficult
If you shim out the housing, I am guessing you would need to have a longer rod by that amount, to maintain the 11mm poking out the other end.
If you mean what Tippie is suggesting, I think he means shim out the bracket that the clutch arm pivots from. It's bolted into the selector case with two M6s - easy enough to space it so the big ball is closer to the 11mm of protruding pushrod.
Yes, spacing the whole cover out (like fitting two gaskets) would have the opposite effect to what you're chassing.
My guess is shitty quality control when making cables. The reason I needed a longer rod was that after new clutch plates and the extended clutch arm kit were fitted, my clutch arm would hit the case before it reached full travel when pulled in.
