The base plate has a marking that should correspond to a marking on the engine case and may be used as a baseline upon assembly. As the flywheel is keyed to the crank, there is no further adjustment possible. Imho, the flywheel marking is solely for strobing/checking the ignition timing.
I'm with Quentin, somewhere around 3mm BTDC sounds about right for a 250 2-stroke single. I've only ever used the flywheel marking for strobing, my Chott runs very nicely with no signs of lag or over-heating.
