Fettling misfire/splutter on SF1. My bike developed a splutter this year, only came on under load, and was only present for a few seconds. I was convinced it was fuel related, so went through the carbs - DelO 36’s, new jets, check floats etc. No appreciable improvement. Last ride of summer it suddenly we came worse, much worse. Had to nurse it for 10 miles and then it suddenly cleared and was normal for the last 20 miles home. I left it alone with the intent of emptying the tank and checking internals for crap and checking the taps. Before removing tank this week, bike wouldn’t start, fuel there so lets’s chase electrics.
Weak spark, worse on one side. Bike has Lucas Rita and a 1980’s KP02 coil. A nice feature of this setup is that with ignition on, closing the kill switch causes a spark. That showed a stronger spark than when spinning the engine. So maybe the battery is past its best, the Rita needs a decent voltage. On removing the HT leads I can see the caps are quite old, and there’s some verdigris on the spike for the HT lead in the coil tunnel. Thing is, the weaker spark is on the coil terminal without the verdigris, which is not what I’d expect. Today I’ll swap the leads over at the coil, see what difference that makes. Then I’ll clean the coil tunnels, fit new HT leads and plug caps (NGK resistor caps, B8ES plugs, copper cored leads). If that doesn’t give a decent spark then I’ll swap the battery out.
From the web, these coils have a dual output wasted spark -
When the magnetic field collapses, the high-voltage surge leaves Lead A, jumps the gap of Plug A into the metal engine block (earth), travels through the cylinder head to Plug B, jumps Plug B's gap in reverse (from ground electrode to centre electrode), and returns up Lead B to the other end of the secondary winding.
