Laverdalothar
- Germany
I know many have used the TEC coils with success in the past, but I was thinking that replacing 37 years old coils with 25 years old ones might not be a wise decission. I made some reserch and found the Dyna coils on the Sachse webpage. Dyna coils have connectors for connecting the ignition lead and as they were roughly the same size as the original ones, I thought I'll give it a try... I ordered 3 single coils, new NGK plug caps plus 2 meters of ignition leads. I also bought me a new crimping tool, specially made for ignition lead connectors to make sure the connectors get perfectly connected to the leads.
Of you go:
The new coils were a bit wider than the old ones, so I could not mount them the same way as the old ones and had to re-position them. I found a nice solution which fits perfectly into the triangle of the frame without drilling one singel hole into the original bracket:
I was unsure if this would really fit into the triangle as space is really tight there, especially with the brackets welded on for stiffening the headstock. But - after a while I found out how it works and mounting it was a question of minutes:
Put 3 fresh spark plugs into the ignition caps, layed them on the cylinder head to ground them, turned the key and pressed the starter - 3 sparks in good quality that I have never seen before on the 1000 SFC!
put the ignition caps back onto the spark plugs and the tank back on, connected the fuel lines and primed the carbs, pulled choke a bit, turned the key and pushed the starter button and - did not start... after a while, it started "farting" (pofff....pofff...) and tried again and again and after some seconds, it barked into life but ran a bit rough. I gave it some time to burn the old fuel and get fresh one and then, it ran better than ever in idle, picked revs quite nicely and was realy running smoothly!
So - good 2nd day of the year! Now it needs a testrun to see if this was the solution to my innitial issues. I hope it was...
Of you go:
