1000 SFC White faced Veglia oil temp gauge
I bought one off Wolfgang a few years ago but if your expectinga white face you might be disappointed. When I enquired about the he did state that the faces had gone a very light shade of beige, so I just asked him to send me the best one that he had.
Tom
I think young Lothar that you are correct😂👍. Maybe that’s why the changed to the black faced gauge on the later bikes.
Tom
Just for info: I don’t want to change due to discolouration. The one I have is black, and revs and speedo are white.
Who knows what was replaced over the time and what not...
pic below is front: my 1000 SFC with black oil gauge (#2934), center the #0001 preproduction bike with a white gauge and machine in the rear is a #3367, a black 1000 SFC Classic with wire wheels and - a white one...:
Thanks, that sounds very interesting. I have a friend that probably also would be interested in a restoration of his beige gauge
With a different sensor (or adding some resistors accordingly), you could also use the one from a 668 Zane potentially... ;-) I have one on my Jota but haven't managed to get it to show the right temperature yet. Pretty sure, for an experienced electrician, that wouldn't be a big issue...
Non working SFC1000 oil temp gauge, after years of not working I finally got around to having a proper look, the problem was the resistor in the purple wire just under the clocks,
Re soldered the resistor and it works again,
You’ll have to dig it out of the plastic sleeve though,
hth, Stuart
