Laverdalothar
- Germany
see - everything will be good at the end...
CLEMTOG said:Why do people lambarst the breakers, and then use second hand parts?
laverdakeith said:Interesting solution Lothar, tighten it up until it strips then back it off half a turn....
Keith
Rockitdoc said:he is going to fabricate four new bolts with the correct radius cut into the center to make room for the stanchions
Dellortoman said:Sounds like a crazy solution to me. If he's going to weld up and re-drill/tap the holes, then why not drill the holes in such a position that you don't need to cut a radius in the middle of the bolts.
Unless I misunderstand your solution, it seems that you're re-creating the problem you have now with the waisted bolts.
Cam
Rockitdoc said:The yield strength of the grade 5 bolts being used is 92ksi ...
torquing them to 65N, as Lothar suggests should not stretch them too much.
sfcpiet said:Normal torquing value for a steel M10 in aluminium would be around 35-38Nm. A bit more than our M9 engine studs...
65Nm will not only stress the bolt, but it might well pull either the thread or crack the opposing part of the yoke, if the bolt holds up.
Laverdalothar said:So - please take it as given, that the repair will be executed professionally and tested accordingly. So - if it works, it works. If not, Scott will have the second option ofputting the thing back on the shelve and take me up on my offer for one of the original, later series sets of yokes.bouncing down the road on his head.
