120 deg crank position
Hi all,
please would somebody please remind me,
when splitting/rejoining the cam chain, due to replacing a shim or two,
I should line up the cam sprockets with the pillar marks, with the link should be somewhere in between sprockets,
should this be at TDC for number 1(left) or number 2(centre) ?
I seem to see both mentioned,
hopefully the crank wont move once the chain is split,
but if it does, need to be able to re time
thanks in advance,
Stuart
Would somebody point me toward the thread that had a picture of the cam chain indicating which side the clip should be,
I know its here, but I cannot find it,
From memory the clip should be on the cylinder 1&2 side, i.e the left side of the chain,
but I have learnt not to rely on my memory!
thanks
(SFC1000 engine)
thanks
(SFC1000 engine)
Correct.
Perhaps it’s just a 120 thing, but it’s been mentioned previously (probably Piet!), that there is so little space between RHS of the chain and a main bearing boss that it’s just possible for a joining link clip to make contact and rub, depending on individual motor tolerance.
I suppose it’s like not turning your fuel taps off, the chance of a problem is small but the cost could be huge.
The basic casting is the same for all triples. Clearance to the main bearing boss can be critical and the chain clip can be swiped off under certain circumstances if installed from the RH side of the chain. Depends a bit on how precisely the crank has been installed and fixed in the cases. I've found witness marks of the chain rubbing on said boss as well as missing clips... both times the clip had been installed on the right. Can't imagine how the connecting link hung on without simply falling out. The pins of the connecting link are just that tiny amount longer that they can bridge the gap to the casting.
Installing from the left is a bit fiddly but avoids any future problems.
Thanks Piet. My Jota has done around 100,000km with the connecting link clip on the right, so I presume there's sufficient clearance for it. I didn't notice any witness marks on the main bearing boss when I had the cases apart to replace a gearbox bearing, but to be fair I wasn't looking for any such thing.
I've actually got the bike up on the lift at present with the tank off (to clean the carbs), so I may as well spend another 10 mins while it's there to lift the lid and swap joining link around around so the clip is on the left.
Cam
