120 Tensioner advice please,
if you are renewing it, then be very careful of the "bend" at the bottom of the blade, most are supplied without this bend and you need to induce it, or the metal of the blade will grind away at the chain, rather than the rubbery bit doing the guiding, look at the existing one to get an idea of the angle needed, its not actually that critical, but you do need to have it "not straight"
