1200 Clutch issues
Leroy
England
Hi all.
I’ve recently acquired a 1200TS thats been stood for some time.
It’s got the hydraulic clutch and there’s no pressure on the lever, there’s a lot of residue on the gearbox cover which leads me to think the problem is the slave cylinder which I believe is incorporated into the outer gearbox cover, also the bleed nipple is sheared off leaving half of it in the cover.
So, is it a relatively easy job ?
Another option I’m thinking of is to convert it to a cable setup, I’m guessing I’d need a different outer g/box cover ?
I’m just racking my brain as to which option would be best.
Any feedback would be greatly appreciated.
Leroy.
Hi Leroy,
It may well be down to the slave cylinder but you would be best to address the sheared off bleed nipple first as without this you will be unable to bleed the clutch system and get any pressure at the lever so that would be my first job.
Not knowing how you are with the tools depends on whether it is an easy job or not.
With the cover off you should be able to inspect the slave system assembly,it may just need a seal replacement if it is found to be leaking.
Use the search function at the top right of this page maybe with "Clutch slave cylinder" in the search bar and you will get various posts on the topic which will help you understand the options and workarounds available to you.
You could as you say go cable set up but you will have to buy additional parts and would that be a cost effective way forward.
Good luck,im sure there will be more advice on its way to you soon.
Schurmy
