Hope this helps, regards John.
Replacing Nippon Denso High Tension ( HT ) connector wires.
updated 5th January 2004 IIS
Nippon Denso Ignition Coil High tension lead replacement ( Pinky, biege colour ) stamped 028700
There is an epoxy resin around the HT cable entry point on the body of the ND coil which can be carefully removed by use of small side cutters.
Take care not to damage the body plastic.
There is two parts to the HT lead, the inner HT lead/copper wire with insulation cover and an outside thin sheath. Pull hard on the HT lead until it comes out of the coil body tube, this will leave the outer sheath still inside the coil tube. By carefully pushing a screw driver down between the sleeve and inner bore of the tube until you feel the remaining epoxy break its bond, continue working around the sleeve until it frees from the bore. There is a standard spike termination at the end of the bore.
A good quality copper core HT lead of 7m/m diameter ( 8 m/m will not fit in the bore ) can then be inserted into the bore ( tube) until is stops and then a good quality silicon sealent or Epoxy can be used to secure the new HT lead to the ignition coil body, try not to use building grade silicon as it cures by liberation of acetic acid which attacks copper components.
Use 738RTV if you can find it at the local electrical wholsalers, or at least neutral cure silicon which is becoming more available from hardware stores.
Once done use NGK spark plug covers with 5.0K ohm supression resistor to terminate the HT leads for clean firing of the spark plugs.
