1980 Jota - Instrument Removal
Those clocks look good, see that metal band on the outside of the rubber? it is held by 3 small bolts just out of picture. If the clock doesn't push out as Paul suggests then undo them and it will all come apart. I would definitely test that rev counter before you go any further.
Is it the bolt in the upper right of this image, between the two clocks? Do all three need to come out or can I just loosen one of them?
IIRC, they are mounted with 2 metall clamps that are screwed to the instrument holder. See:
all 3 screws need to come out, but at least the top one (the others can be just losened, so you can move the metal strap enough to take the instruments out)
It's one metal clamp. Two is because it's broken in the middle. They all do that.
If testing really does fail to move the needle... You need to remove at least two of the three retaining bolts that secure the metal band around the instrument rubber rings. One is arrowed. The other two are at each end of the metal band clamp.
The bolt sits with a large washer and rubber grommet to isolate vibes.
