steve.bennett
- burbage village .leicestershire
According to the Green Book the original battery spec was Fiamm 61F5P .32 amp 12volt. i currently have fitted an Exide at 30 amps this struggles and will not turn over quick enough to excite the Bosch ignition. And the battery dimensions are slightly smaller to the carrier, obvious to me battery ageing but not really man enough in the first place. is there on the market a battery of the correct dimension's to fill the carrier have 32 amp or more cranking power especially when cold.
i have had the tank off plugs out of the head, and connected to there H.T. leads earthed and spun the motor on the starter good spark on all three plugs.is there a member out there can point me in the direction of the correct physical size battery of 32 amps or even more..i do prefer top wet cell,
thankyou .Mr,steve.Bennett ILOC member 4269J.
