steve.bennett
- burbage village .leicestershire
Original BTZ ignition Nippon- Denso Coils, pick ups,BOSCH -Amplifiers NGK plugs all original system still fitted.
virtually will not start the odd miss fire and eventually wets all 3 plugs. i have removed all 3 plugs connected to the NGK plug caps and earthed to the cylinder head, with no compression resistance and engine turning over faster than normal, sometimes all three spark though it seems weak at times.i have checked the Amplifier connections very good condition no corrosion ,fuse box original all in good condition ,Handel.LL bar kill switch operates no short!Laverda multi-terminal block nose of seat just under the tank all connections firm and no corrosion no bare wires,a good earth strap from the battery,the two ballast resistors nr coils have good firm AMP spade connection.
some advice to point me in the right direction to a fault that may cause this condition via the forum would be appreciated .Mr,steve.Bennett Rejioned member 4269J.
Thankyou.
steve.
Thankyou.
steve.
