wallaman
- Arizona, USA
New to the Forum, but have been riding Laverdas since the '70s. Selling my original paint 1983 RGS1000 in Executive Trim. This bike went through an extensive mechanical restoration by well-known Laverda expert Scott Potter about 10 years ago and has only been ridden about 1500 miles since. Current mileage is approximately 28,300. (I have extensive documentation from Scott Potter on his work.) His summary below:
Disassemble the machine down to every last nut and bolt.
Send out all chrome components to be replated.
Strip frame, center stand and rear fork to bare metal.
Fabricate gusset plates to strengthen headstock.
Powdercoat frame and rear fork gloss black.
Renew headstock bearings and rear fork bearings.
Disassemble engine.
Clean sand cast engine components.
Bead blast as necessary.
Follow with hot tank wash and clear out all passages with compressed air.
Polish all alloy covers.
Replace wearing components as necessary.
Lighten clutch basket and pressure plate.
Machine true and lighten clutch drum.
Send out cyl head for 3 angle Serdi seat cut.
Reassemble engine to factory tolerances.
Check valve timing to published specs.
Disassemble, clean and inspect starter clutch.
Reassemble with new springs, plungers, and rollers.
Refit to engine.
Refit engine to chassis.
Disassemble front forks and clean.
Check fork tubes for straight and true.
Polish fork tubes.
Fabricate adapters for cartridge emulators.
Modify damping rods for cartridge emulators
Reassemble with new seals and oil.
Refinish yokes and instrument mount.
Refit forks to chassis.
Renew rear damper assemblies with custom Works Performance units (since replaced w/ new Ikon units).
Disassemble brake hydraulics.
Clean and reassemble with new kits, pads and pistons.
Remove rotor surface area of iron oxide.
Mount rotors to hubs with new fasteners.
The bike is currently fitted with Mikuni Flat Slide carbs, but stock carbs are included with the sale. The bike just had an oil change and a new battery installed and runs as it should. When I rode it today, I noticed the fuel gauge and oil temp gauge weren't working but pretty sure I just forgot to reconnect harnesses when I had the tank off last. I am getting old and have just had some recent health issues and this bike is just too big for me at this stage of my life. My loss, your gain. Asking $15K obo. The bike is located in Phoenix, AZ USA. If you have a serious interest and have questions, please message me here or contact me at wallaman at cox dot net
Disassemble engine.
Refit to engine.
Polish fork tubes.
