breganzane
- NSW Australia
Laverdalothar said:not much in that section, see: https://www.stein-dinse.biz/Moto-Guzzi/Vergaser-u-Luftfilter/Vergaser-komplett/Dellorto-Vergaser-PHM-38-BS1-L-Fl-Ch-04813::1075.html#prettyPhoto
Not sure what you mean. The photos clearly show a totally different casting to the PHF with no provision for the inlet-side bracket holes. The specs also show a 4mm larger inlet thread (which the Lav bracket has to fit over) - little wonder it was a bugger of a job for whoever did it.
The PHF 34 was absolutely no problem, nor would be the 36 from what I can tell.
(banghead) (cheers)
