It's approx a grand Oz to have Maxton fit kits to your forks, not including post both ways which would be eye wateringly expensive. Maxton does compression in one leg and rebound in the other and you can have hidden valving clickers or exposed clickers. Those 38mm fork kits tubes and alloy bottoms according to their Advanced specs include top and bottom bushes, which makes them virtually unique as none used std by all the Italian manufacturers had bushes. They, the fork makers not Maxton also include SFK seals that cost $120oz as well. Both those inclusions reduce friction loads way more than just the alloy bottoms rubbing on the steel tubes. Very very expensive but really high-spec gear.
