Hi All.
I've attempted to search for some answers but to no luck.
I have 2x Sets of Marzocchi 38mm forks im trying to sort out and have some questions I havnt been able to answer yet.
Question 1 - Set 1 has Brake Lug/Hole spacing for F08 and 300mm disks - but i have been unable to find any bikes that originally came with 300mm Marzocchis and 300mm disks - as far as I know all the Laverdas with 38mm forks had 280mm disks and the same with Ducati? - These forks have 600mm tubes in them. - anyone have any idea what bike these may have come out of?
Question 2 - Springs and spacers - the First set has what I think is the standard set up - a spring that is partly encased in a steel tube and a ~40mm spacer on top. The 2nd set has a much bigger diameter spring and no steel tube, and just a couple of washers as spacers (prob 5-8mm all up) - Is it correct that the original forks had the steel tube? Assuming the larger spring in the 2nd set is aftermarket? - Set 2 has 580mm tubes
I'm likely going to upgrade them with a set of Sports Valve damping units (or Racetech Emulators - havnt decided yet), but just interested to know what ive got before i get to carried away
