martymoose
- Sydney, Australia
Finally have some time to spend on the 3C. First problem I've come across, the nylon wheel on the cam chain tensioner has seized and worn a flat spot. I have a new one, but it involves making up a new rivet to hold it on the pivot. What is the preferred pin material, cut down a bolt? Heat the pin to mushroom the head may effect the nylon wheel, did the factory just bash the snot out of the ends of the pin?
