SandPebbles
- Madison, CT U.S.A.
I need a little Laverda history and advice regarding the headlamp shell for a 3C. I have four 180 mm headlamps shells that I have somehow collected, and two of them have large holes for the wiring on the back. The holes are grommeted and measure about 1 1/2 inches in diameter.
The third shell has no hole in back (this shell was on the motorcycle when I purchased it).
All first three shells have the small hole in the bottom. (The fourth shell is beyond description...looks like PO was a little too eager with a hole saw).
My question is this...I can't see how the wiring would fit tightly in the large grommeted hole of the first two headlamp shells. Where these
holes (with wiring loom) sealed somehow from the factory? Or did the wire loom just run through the large hole loosely? It looks like this would be an easy ingress for water and dirt. Is this a concern that has been dealt with?
And of course the two shells with the large openings that I have are the ones in the best condition. I can't seem to find any information on this in the forum or elsewhere. Any insight would be appreciated.
