Jo
- Cologne, NRW Germany
My 3c had been having trouble starting for a while.
When I pressed the starter button, different things happened. Sometimes the starter motor pulled, sometimes it only turned for a fraction of a second. In any case, it was an inconsistent picture. However, with patience and several attempts, it always started.
After I had checked the starter motor with friend Jürgen in May and installed an additional earth cable directly from the battery to the starter motor before the trip to Breganze, which didn't change the behavior described above, it refused to start for the first time on Sunday before the trip home from Laverda-Meeting in Heftrich/Bauschheim. A mate helped out with a power bank, with which I got it running.
But now it was clear to me that this problem couldn't be put off any longer.
Today I removed the starter relay and the two fat positive cables. All connections had been found tight and uncorroded. Took the whole caboodle and drove to Jürgen again. We opened the relay, it looked very good overall, except for the contacts, which were slightly burnt:
We smoothed the contacts with emery cloth and reassembled the relay. Jürgen then made me two new thick positive cables - thank you very much for that! I've just put everything back together and the starting behavior is like new.
If the relay starts acting up again in 50 years, I'll complain to Bosch!
Jo
Jo
