Greg,
Most often the cross-bar that pushes the pressure plate has a neat hole worn in it. Did you check while the clutch was apart? Unless the clutch has been badly abused, wear at the rod ends and the bearing are negligable.
The cross bar/pushrod contact is the least lubed part in the actuating train. Normally, the rod will spin with the cross bar, but if there is the least bit of friction between the rods and bearing, the cross bar and rod will start to rub.
