andychain said:The only thing it will help with is it will lessen the noise.
andychain said:Andy
Putoline do the same wax
andychain said:Just make sure you boil it for long enough as you have to get the chain
which is a big ol lump to the same temp as the wax.
The chain should be hot enough so 99% should drain back into the tin.
Triple those k's left if you flip the sprocket and reverse the shark's teeth!!Dellortoman said:Still a couple of thousand km in that sprocket.
The one below was on Tim's 3C a couple of years ago. He thought the clutch was slipping but it was the chain jumping teeth. Did another 300 km to get home after the photo was taken.
martymoose said:Chain lube? I don't need no stinking chain lube!!!!!
