3CL/Jota front wheel
Chris put all the bits, spacers, speedo drive, wheel etc on the floor. The centre line distance between the forks is 195mm. Measure and re-measure each fork leg width and start subtracting. Saves all the rooting around.
Well bugger me! You're absolutelu right Poff and others. I just went and had a look at my Jota's front wheel and yes, there are spacers between the disk carrier and the wheel. I'd never noticed that before, even though I'd recently had the disk carriers off.
Without taking it apart to measure accurately, the hub measurements as near as I can determine with a pair of dividers and tape measure in bad light are 74mm without carriers, 89mm with them.
Note to Chrisk:  Don't use these measurements as a reference for machining operations  ;)
Cosi said:
:o :o :o,
not new i hope
Yep. I did ask some time ago about the new compound TT100's and nobody said they were crap so ...
If they are anything like the originals I'll be changing them in 3 to 5 thousand anyway.
