3CL rear brake lever side?
someguyinohio
Hi everyone.
Happy to own what I believe is a dog eared ?76 3CL #3580 with rear disc brake. Needs many many parts among them both foot pedals and all linkage are missing. I can?t tell if the brake pedal is on the right ? This is the same side as the master brake cylinder.
QUESTION.
Is it true that which ever side the rear master brake cylinder - is - the same side as the brake pedal?
I would think for the brakes you wouldn?t want the clumsiness and fallibility of connecting rods etc. moving the actuator to the other side ?
Mine has the Rear master cyl on the right. But then they moved the tranny lever to the left with the cross frame tubing / arm assembly which I have. ?
Trying to understand this bike. I see the rear master cylinder on
both sides...
Thanks all.
Yep, if the master cylinder is on the right, that's the side the brake pedal would have originally been on. You also have the cross-over gear linkage, which makes sense if it's an original import into USA (left side gearshift was a USA requirement).
Being an early 1976 bike, I suspect yours would have originally had the standard forward footrests (not Jota rearsets) when it left the factory.
The cross-over gear linkage can be made to work very well. I have exactly the same setup on my 1976 3CL/Jota and the gearshift is not at all loose or vague. The rear brake is a little less effective of you have rearsets, but still can be made to work OK with a bit of tweaking.
It sounds like you've acquired an interesting project.
I've 3586 which I bought from USA. Only 6 bikes away from yours...
Happy to send you some pictures of the brakes etc if you like.
John
