Never had experience with the balance factor guff.I have read a few times about removing these shafts on road race bikes to increase power and reliability. Will that produce the vibes contained by their action? What's the story regarding this mod?
Last year I had a discussion with Richard Bulkley why it is hard to find the neutral at our Zane 650.What makes you think I don't ride it? It did a few hundred kilometres of dirt a while back on a solo trip I did through The Wadigans and out past St Arbans. It's just painful in traffic, not being able to select neutral.
We find out that the selector drum has a raised ball on it which presses against the contact off the neutral switch.
When the switch is to deep it needs too much pressure to push the switch.It push back out of neutral.
Put an extra ring under the switch so it’s less deep.
I did at my 650 and it works! Much easier to find neutral!
500 and 600 Atlas are the same.
Hi Vince, it is at the sprocket site. Because yours is hard to get in neutral I would start to put in two or three extra copper washers. When your neutral light doesn’t work, take one washer out. Then you have done the maximum. Check oil leaking afterwards.Mate, I hope so. Otto, where is this located on the engine, and is it hard to get assess too it? When you say ring, is that a copper washer like on the neutral switch on Briganze Triples?
