Corinne, my wife's 500 is afflicted by intermittent cutting out when shutting the throttle coming to ,a stand still. Carbs would seem to be the obvious place to look, but they've been off a couple of times, cleaned and blown out. I did find a float level that was rather low but that's all.
Otherwise, it works fine albeit a slight fluff when coming on to the needle which an in depth looking at carb settings would no doubt cure.
Could this intermittent cutting out be ignition related? The machine is running the original Bosch setup and ND coils.
Thanks for any tips.
