Thanks Maurice. I'll look this afternoon. My wife's 500 is playing up after a partial rebuild. Uneven idle and occasional stalling. Carbs are ok but a quick strobe flash yesterday appeared to show that timing was way out, which is strange since I didn't touch the pick ups though I did have the primary cover off.I have strobed mine at 3600 at 32 deg max, idle at 1000- 1100 about 10 deg
Thanks Vince, will give it a try.I think you answered your own question Paul, pick wire insulation.
Redax Ignitech?
I wish.Can you convert to points, Paul? Sorry for stating the obvious.![]()
Thanks Vince.Probably overkill but available if it suits, they sell the wire as well. Use the correct wire spec
bosch pickup wire replacement manual
step by step instructions on how to replace the wires on your bosch pickups in your bevel drive Ducatistore.bevelheaven.com
Compression ration appears to be standard. Head was off for a gasket change and pistons were flat.There's your problem Paul insulation breakdown on the Bosch pickups, they can be repaired but it can be costly as they will have to epoxy the connection at the pickup itself, will solve your wild variables for sure, your max advance is up there what compression ratio in your engine??
Thanks Rob, I'll try swapping boxes. The system is the same as a 180 with 2 boxes and 2 pickups 180° apart.Have you checked the pickup resistance value? If so, what is it? But reckon you have a duff BTZ box.
Not familiar with 500 arrangement but presume you can swap the boxes over to confirm?
Correct Vince, if we are talking original Bosch inductive pickups ( PUP )and BTZ, as the impulse cam approaches the PUP a positive going pulse edge is produced, as the impulse cam trailing edge leaves the PUP a negative going pulse is produced. Possible to reverse these pulses if the PUP is reversed wired. The trailing negative pulse is what the BTZ uses for idle advance, nominal 5-8 dBTDC. Pole face distortion ( pulling towards the impulse cam lobe ) is chronic on Bosch PUPs.Didnt someone say something about fitting the yellow wires the opposite way around polarity wise resulted in full advance at idle. Just repeating what I remember was written. I don't know why it would only affect one cylinder thought. If it isn't that it's the box. Is there 2 yellow wires per cylinder?
