Lyndoneil
- Towcester uk
I'm having trouble getting a decent spark at my plugs and hence starting problems, not made easier with high comp pistons and high lift cams, have shortened the ht leads to good wire, have not checked the coils yet apart from making sure all connections are good, as it does not appear to be that easy a task for some one that is not actually an accomplished auto electrician, but I have seen on other threads relating to the triples and 750s that the ballast resistors on the coil low tension leads are not necessary and can be removed to increase the voltage to the coil. Would this be applicable to the 500s too, I've removed them at the moment and the spark seems brighter, but don't want to damage the Bosch control boxes.
