72 rubber swingarm
Trevor Crack
Bury St Edmunds
Well this one is semi rigid! My first time with a rubber bushed swing arm!?
The shaft/spindle is solid turns with what movement I have when I move the swing arm Need some ideas
Trevs72SP
I would weld the nut on one side, fire WD40 at it whilst trying to turn it with a nut gun, go back & forth until something gives.
We used to do this on Hondas, if you can get it to move the WD will find it way in. You may have to whack at as well.
If you do go down the route of destroying the swingarm, I have one complete with spindle.Obviously if you can pre soak it in penetrating oil prior to the big day , all the better.
