Bike starts and idles fine, first 2-3 miles is fine.
Then idle drops off, rolling on the throttle causes bogging, no fuel type sensation.
If you shut if off and restart it idles fine but won't accept any throttle. If you let it sit for 20mins or so it will repeat the good for 2-3 miles sequence and then stall.
Tried cracking gas cap to see if was a vaccum issue, no change.
Rode it home with the choke on one carb open and it ran like crap but I got home.
Carbs rebuilt appox 25 miles ago.
Running velocity stacks and no filters. Only driven on clean paved roads and in dry weather..
Pulled one bowl and it was clean.
Drained the tank and the in-tank filters were clean and minimal crud came out. Looked like flaked off paint from around the gas cap.
Any suggestions?
I'm guessing a complete carbendectomy is in order.
Thanks.
Brian
Any suggestions?
Thanks.
Brian
