Casor
- United States
Hey everybody, I bought an SF2 in October and in the interim sourced some needed cables and rebuilt the Dellortos. Attempted to start it today and got no spark on either side. Engine turns over freely and all the electrics are old but stock - points, coils, wires, handlebar switches. The bike does not appear to have been molested to any great extent. It's just old.
The points looked a bit shaky, but good enough to work. We cleaned them since they had some dirt etc on the contacts. We checked all the critical power spots - getting power to the coils, the starter works fine, and have power to the points. The coils were disconnected and ohmed and found to in spec. We reset the points to the spec .5 mm or whatever it was. The batt was fine at just over 12v. Plugs were filthy so I changed them and the spark plug caps were resistor type which they should not be - OK but I should get something. Even if the timing was off, I should at least be getting spark at the points and plugs. Nothing.
The only monkey in the wrench I could not check were the condensers and I have had issues with other bikes if these are old. I have some on order but I feel that I should at least have gotten something other than no spark at all on either cylinder.
I am new to these things but have the shop manual and went through it to make sure we covered the bases.
What am I missing here guys?
