read both the Phil Irving books while on a train trip from Irkutsk to Magistrany in Siberia, 36 hours on an old wooden Russian rattler going through the Siberian forests, outside temp around -45C
interesting train trip and very interesting books, 2nd book was his autobiography (think that is the right term)
so been twisting and turning all night trying to sleep tossing up 360, 90, 76, 180 and all variations in between
current plan, have a think about machining a new insert for my crank fixture to allow me to press at 76 degrees, is around 8 hours of machining time
design is already done as I made an insert to allow me to do 120 cranks in the 180 fixture, is just a matter of making same insert with different hole phase
pick up the bare crank tomorrow morning and strip and repress back together at either 76 or 90 degrees and take back to get balanced checked, by rights balance should be the same
I'll get Volker Sachse to make up new ignition boards to suit the twisted twin phase, be it 76 or 90 degrees
will worry about the camshafts when we get there, concentrate on the bottom end first
this will be interesting, getting bored building the same style triples all the time
