750 need exhaust rose, tappet cover,brake springs etc
Andysouthampton
Leicester, UK
I guess a 750f with engine number 6913 would date trom around69/70, anyone know any history of this bike,its an ebay job, its got a few FSC parts like many others but looks like it's been off the road for many years.
It's missing loads of bits and I would love to buy at least some used rather than new parts if possible.
Need tappet cover 58110103, exhaust rose, rear brake shoe big springs,brake cables front and rear (to copy) and an ignition points plate, spray clutch bits etc . I'm in leicester, andy.
Andy
I have loads of old 750 parts, can you send me a conversation specifically on what you need, I should be able to help.
Alan.
h
Alan, my references are from laverdaria catalogue. It's a long List!
One tappet cover 1.55
One exhaust rose, its the 7mm studs but sure an 8mm one would be OK 1.21
Four of the exhaust 1/2 rings 1.62
I have two good std 80mm pistons and the bore looks good but need one piston set of std rings
Two brake springs, two of the big ones and 2 of the little ones 22.60 and 22.60a, for rear drumbreak.
A front brake torque arm, from top of drum to a lug on fork leg.
Clutch and brake lever
Front and rear brake cables
Ignition points backplate and points condensers etc, or I may go electronic, I have advance etc but not the90mm front plate with the points on.
Sprag clutch 6 springs and 3 spring caps, I have new sprag clutch rollers 10x10, so 3.47 and 3.47a
The bike and engine say lav 750f 6913
Any of these bits will help even damaged cables as I can make patterns.
I'm based near Leicester,thanks.
